Question on the TA girdle
Old Jan 9, 2005 | 09:15 PM
slowprocess's Avatar
Default Question on the TA girdle
I checked around on a few things about the TA girdle. I noticed they were listed as a 7.5", not an 8.5" 10-bolt. Is this still what I would need for my application? Thanks guys. I'm looking at that one that has thunder racing etched on it. Looks sweet to me!
Jeremy
Old Jan 9, 2005 | 09:17 PM
You'll need the 8.5" cover to fit your truck.
Old Jan 9, 2005 | 09:18 PM
Cool, thanks whitt!
Old Jan 9, 2005 | 09:51 PM
budhayes3's Avatar
PT's Slowest Truck
I called the folks over at TA and told them what I had and they sent it to me. One thing that I did find out though, I would use an OEM gasket as opposed to the one that comes with the cover. The one that comes with the cover partially blocks the two holes in the housing that are used to supply gear oil to the bearings. My gasket blew out in those 2 spots (better the gasket than the bearings). I installed a factory gasket from the dealer which doesn't even go near those holes and haven't had a problem since.
One other issue, it came with standard bolts and our rears take metric...there's even a note in the package stating which ones are needed. You could pre-order them so you don't have the hassle of having to get them at the last second, or do what I did and hit a Lowe's and 2 Home Depot's to gather up enough bolts to get er done.
Old Jan 9, 2005 | 10:23 PM
Mr. Sandog's Avatar
Do you have a GM part number for that gasket?
Old Jan 10, 2005 | 09:07 PM
budhayes3's Avatar
PT's Slowest Truck
part# 26066456 list: $5.95
Old Jan 10, 2005 | 10:38 PM
Texas Terminator's Avatar
11 Second Club
don't use a gasket. use some permatex grey. 1/4 inch or so bead all the way around, and go around both sides of the bolt holes too. never leak. just make sure your surfaces are CLEAN first.
JordanH
Dec 25, 2015 08:32 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
