Question on start up
Old Aug 16, 2005 | 02:25 AM
ap2002's Avatar
I have seen this happen to my dad but I dont remember what it was, it was either the Idle Control Valve or the Fuel Pressure Regulator, but I would change the spark plugs and the fuel filter too..
Old Aug 16, 2005 | 10:32 PM
Phatchevy's Avatar
alright i'll try it this weekend. lately it has been hard to start. like NORMALLY i would turn the key and it would immediatetly start. now i have to hold the key and let it crank for a while and then it will start. once it's on for like 5-10 seconds it's perfectly fine.
how often should the PCV valve be changed out? i've never done that. also how do you change it?
Old Aug 17, 2005 | 06:44 AM
JERRY2500's Avatar
14 Second Truck Club
I'm with Chevy6000vho on this. My truck did the same thing after a topend clean. Changed the plug and solved the problem.
Old Aug 17, 2005 | 07:54 AM
JUSTINASS's Avatar
I am usually on ls2.com but I noticed ya'll have a truck section.
I am having the same issue w/ my wifes 01 Tahoe.
At start up the rpm's will drop and surge - once you give it some gas it does not hesitate.
It also occurs other times while coming to a stop sign/redlight. It is not consistant though. It seems to be worse if the A/C is on.
70K miles original plugs/wires - I plan to change them this weekend.
Fuel injector regularly
Fuel filter 10K miles ago
PCV valve @ every oil change
What do ya'll recommend I try after the plugs/wires???
Idle control valve? How much is this?
Fuel pressure reg. How $?
Old Aug 17, 2005 | 08:43 AM
BLACKND's Avatar
Seems I'm having similar issues as Justin. But mine seems worse, it is surging real bad from a stop light or sign to about 60 mph. It seriously feels like someone is lightly tapping on the brake pedal as I am driving or accelerating. It only seems to do this on part throttle situations. AT WOT it drives fine. but when I let off the gas to coast down it starts again. Really driving me mad.
I have changed out spark plugs and cleaned my throttle body. Plugs are NGK TR55 with about 20,000 miles on them. MAF could probably use a good cleaning.
As far as the Fuel Pressure Regulator, PCV Valve, Fuel Filter, and ICV Valve, where are these items located, how easily changed and where are parts available?
Also, I have the electronic drive by wire throttle body and have heard that these sometimes after time have a difficult time idling right. I have heard some folks speak of a way to repair these, I have not heard the lesson yet though, so I don't know if its a lube process or actually taking the unit apart and fixing it. I had this unit ported and is not the original off of my truck.
Oh and also, I know that mine needs to have the idle tables raised a tad since the ported TB was installed, prior TB had the hole in the blade, but this still doesn't seem to be all the problems
ferrellrooster
Mar 6, 2025 03:22 PM
WarbirdLS1
Aug 8, 2015 10:53 PM
76k10chase
Aug 4, 2015 03:28 PM
USMCvet0311
Aug 1, 2015 07:45 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
