Question for Parish
Old May 14, 2004 | 02:58 PM
Default Question for Parish
How do you tap the oil pan for the oil drain back line. does alluminum fillings get into the oil pan ?? Also where do you tap in the oil feed for the turbo on the 6.0L ?? Thanks
Old May 14, 2004 | 03:05 PM
parish8's Avatar
single digit dreamer
i drained about 1/2 of the oil, then driled a hole and taped it. some metel fell into the pan i am sure. i changed the oil fired it up for about 1 minuted and changed it again. then changed it again after a few hours of running.
i just used cheap oil for all of this since i knew i would be dumping it out quickly.
the feed line taps into that fitting near yout oil filter, it looks like it was made to hold an oil line.
Old May 14, 2004 | 03:15 PM
There are manufacturers that make a special tap that makes the chips fall the opposite direction instead of inside of the pan
I will try and look up the manufacturer.
Old May 14, 2004 | 05:02 PM
thanks guys i appreciate the input. I will check back to see if find that manufacture.
Parish one more question, do you happen to know what size fittng and tap you used ???
Old May 14, 2004 | 05:13 PM
parish8's Avatar
the size would need to match whatever line you are trying to hook up. for the cmotorsports kit the return line needed a 3/8" npt and the feed line i think was a 1/8" npt.
Old May 14, 2004 | 05:31 PM
GMC SKI's Avatar
Yep that's correct on those 2 sizes the feed is -4an and the return is -8
I did the same with the oil
I actaully drilled it with a full pan of oil and it spit out the shavings and oil
at the same time
Old May 14, 2004 | 10:25 PM
thanks again guys, good luck with your trucks
JordanH
Dec 25, 2015 08:32 AM
pewter00
Sep 13, 2015 11:14 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
