Question on cams
Old Feb 12, 2004 | 05:48 PM
burbman's Avatar
Default Question on cams
What should I be looking for in a cam that will compliment a twin screw blower? I do not know a lot about cams, but will probably be looking into one in the next few months and wanted to get some input on what I should be looking for.
Old Feb 12, 2004 | 09:00 PM
Flem's Avatar
I guess from the year of your truck your running a SBC . you'll want a split pattern cam w/ no more than 210 degrees duration @.050" and about 6-8 degrees more on the exhaust. with a sbc you'll probably be around .480 to .500 lift. a blower wants limited valve overlap so you'll want no less than 114 degree LSA. although the 2800 stall converter will allow probably another 8 degrees duration on both lobes if your looking for a big top end run.
Old Feb 13, 2004 | 06:42 PM
burbman's Avatar
Yes it is a Vortec 350. Thanks for the info!
Denali08
Aug 9, 2015 04:34 PM
Jake75
Aug 5, 2015 01:26 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
