Question about shift points/timing with LS1 Edit
Old Oct 12, 2004 | 02:44 PM
Default Question about shift points/timing with LS1 Edit
I'm about to tune a truck for the first time. The owner wants to stay on 87 octane. How much timing is everyone adding without needing more octane to combat pinging/detonation?
Also, what shift points would be best with a 219/222 .563/.566 115+4 cam and stock heads? We will not put the truck on a dyno to be tuned for a couple of months, so I'm looking for safe numbers right now.
Old Oct 12, 2004 | 03:27 PM
FILE's Avatar
that cam should pull up there. I'd say 6400-6500.
Old Oct 12, 2004 | 03:35 PM
one03sierra's Avatar
Formerly one92rs
Talking
i would try the 30* timing range and see what is up.
Old Oct 12, 2004 | 03:38 PM
BigKID's Avatar
I would say anywhere from 2-4* across the board for timing. Do you have any scanning capabilities? You could add timing till you see kr then back off 2*.
Is this cam in a 5.3?? If so it is probablly going to want to shift in the mid 6K region. I have mine set @ 6100 with my 214/216 113+4.
Old Oct 12, 2004 | 03:45 PM
MacADaYear's Avatar
Is that the way to go? Im just curious so I know when I start doing my own tuning
Old Oct 12, 2004 | 03:57 PM
Yes, I have Autotap to scan with.
This cam is going into a 5.3. Has anyone had internal problems by revving a stock 01' 5.3 to 6500?
ferrellrooster
Mar 6, 2025 03:22 PM
zblee
63
Jun 10, 2023 01:25 PM
nrmskate
Aug 11, 2015 02:44 PM
USMCvet0311
Aug 1, 2015 07:45 AM
Black-Syde
Jul 6, 2015 02:12 PM
