question about nelson fan harness?
Old May 3, 2005 | 02:12 PM
BigBlackAv's Avatar
where can you order it from?
Old May 3, 2005 | 02:20 PM
JERRY2500's Avatar
14 Second Truck Club
One of ower sponsors>>>>>>>> Nelson Performance>>>>>>>
Old May 3, 2005 | 04:00 PM
KySilverado's Avatar
Originally Posted by Okie02
sounds good except for one fan turning on high and one on low and all that crap...im not sure if im gonna get one...how does everyone else like theirs?
Flickers my headlights even with 145Amp alternater. The fan will kick on any time the AC compressor kicks on which is every 30 seconds I believe. Even when the truck is running down the highway at 70mph and not needed. I'm gonna modify the circuit so that the AC fan only comes on when absolutely needed. Annoys the heck out of me.
Old May 3, 2005 | 04:22 PM
shupe's Avatar
KySilverado -
Very intersted in this mod. Drives me insane. Keep us updated what you find.
Old May 3, 2005 | 04:31 PM
rosscob's Avatar
I would love to know how you fix this.
Ross
Old May 3, 2005 | 06:23 PM
Originally Posted by shupe
KySilverado -
My plan is to put one of the bulb type thermostats on/in the A/C condenser. Tie it to an adjustable thermostat just like used in aftermarket e-fans. Use the outputs from the controller that usually turn on a fan and put them in series with the Nelson A/C circuit. So the fan should only come on when the A/C condensor is hot just like turning fans on when the radiator is hot. When running down the road the AC condensor shouldn't get hot enough to trigger the circuit but sitting in traffic it would. I just have to figure out what temperature is to hot for an A/C condenser. I'm gonna unplug the A/C fan and stick in a thermometer int he condenser and run the AC to see how hot it gets when no air flowing over it. Does anybody know what this temp is?
Should work
Old May 3, 2005 | 07:41 PM
BigBlackAv's Avatar
i believe it would vary...i think you need the discharge temp to be at 12 warmer than ambient and that is the temp that you want the inside also to be blowing 12 degrees cooler than ambient in the inside. It still sounds like a good idea...the fan kicking on every 30 sec. is very annoying.
good luck
Old May 3, 2005 | 07:45 PM
LedFut's Avatar
Im thinking about just wiring it up to run power and just saying screw the whole harness.
Old May 3, 2005 | 08:15 PM
rosscob's Avatar
I've heard someone else wasy going to put a high pressure switch on the A/C line. I have not heard any results yet, but have been keeping my eyes and ears open for a viable solution.
Old May 3, 2005 | 08:39 PM
hhmmm..i think im gonna just go with the digital dakota controller instead of the nelson harness
