Question about evap system
Old Dec 16, 2006 | 11:25 PM
thunder550's Avatar
High on diesel fumes
Default Question about evap system
The SSR manifold I bought has a fitting built into the intake where I can plug in my evap line from the gas tank. Only problem is that it would bypass the evap solenoid completely if I did that. Do I need the solenoid? What does it do?
Old Dec 17, 2006 | 09:12 AM
agreif's Avatar
I that you shoudl be ok. I know if you disconnect that line at the tank you will get a small or gross leak code. but if you effectively plug that line, all that I gather would happen is that instead of purging gas tank vapors into your intake, now the canister solenoid will vent it to atmosphere. As long as you keep that solenoid hooked up and allow the PCM to cycle it to make sure it's working I think you'll be ok.
http://web.bsu.edu/tti/5_1/5_1e/5_1e.htm
Old Dec 17, 2006 | 10:04 AM
thunder550's Avatar
Actually what I am talking about is running the line straight from the gas tank to the intake manifold and removing the solenoid, so the tank and intake would always be "connected" directly.
Old Dec 17, 2006 | 08:59 PM
agreif's Avatar
I think the only problem you may have there is a believe the computers do a startup routine to make sure that solenoid is operating. Not sure what happens when you remove that solenoid. Maybe someone else has a better idea. I looked into this when I cracked my evap can, but I think I forgot it after smelling that damn differential fluid a couple weeks back.
Old Dec 17, 2006 | 11:32 PM
DrX's Avatar
DrX
The vent solenoid on the canister is normally closed when the engine is running and open when off. The purge solenoid normally does not open until the criteria in the tune are met(see tables B0501 to B0504 in EFILive). Not sure what will happen if it is always open.
There is a diagnostic at startup that cycles the 2 solenoids and monitors tank pressure/vac to test for leaks and proper functioning of the components. So you will have some DTCs to disable.
Old Dec 18, 2006 | 01:54 AM
thunder550's Avatar
I think I'm just going to try and relocate the solenoid and run some rubber hose in place of the hard line that was on it.
Old Dec 18, 2006 | 08:48 AM
DrX's Avatar
DrX
Looks like the stock setup has the solenoid mounted on the fuel rail with a second hose to the fitting.
Old Dec 18, 2006 | 09:42 AM
thunder550's Avatar
Yeah I've seen that diagram...I don't have the stock SSR rails, I have the stock truck rails mounted to the SSR manifold. I may see how much the SSR setup costs with lines and everything, but I think I'm just going to try to find a way to mount my original solenoid somewhere and make my own lines. Thanks for the info
Old Dec 18, 2006 | 10:07 AM
BlownChevy's Avatar
blownerator
25 Year Member
put it inline with some good rubber hose. Do not eliminate it.
Old Dec 18, 2006 | 10:18 AM
thunder550's Avatar
Would you mind explaining?
