Question about E-fans w/ VSC.
Old Sep 23, 2003 | 03:59 PM
abbo7's Avatar
Default Question about E-fans w/ VSC.
Will this VSC kit work on a 03' Chevy w/ LS1 fans http://www.truckperformance.com/prod...oductID=422374 , also with this VSC it says that it will run 60-100%, soft start, and temp sensitive, however how will it respond if you install a 160* t-stat. And finally, does this VSC have a manual ON/OFF switch? Thanks for the help.
Old Sep 23, 2003 | 04:09 PM
jdpanero's Avatar
Default Re: Question about E-fans w/ VSC.
I use an on/off switch w/the vsc. It is very simple with their diagram an instructions they send. There are a ton of ways to wire it up.
Old Sep 23, 2003 | 06:09 PM
Flyer's Avatar
For everything you said the VSC will work fine. I thought there instructions blew though, it was a waste of time to even attempt to figure them out I thought, but once I did get it working, everytihng is great. My truck holds a steady 170-180 even in traffic.
JordanH
Dec 25, 2015 08:32 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
