Question about E-fans w/ VSC.
Will this VSC kit work on a 03' Chevy w/ LS1 fans http://www.truckperformance.com/prod...oductID=422374 , also with this VSC it says that it will run 60-100%, soft start, and temp sensitive, however how will it respond if you install a 160* t-stat. And finally, does this VSC have a manual ON/OFF switch? Thanks for the help.
For everything you said the VSC will work fine. I thought there instructions blew though, it was a waste of time to even attempt to figure them out I thought, but once I did get it working, everytihng is great. My truck holds a steady 170-180 even in traffic.
TAPyvehc93
Sep 12, 2015 08:19 PM
carid
Sep 10, 2015 09:07 AM
