Question About Comp Cams 918 Springs
Old Apr 20, 2010 | 03:45 AM
dug's Avatar
dug
Banned
Default Question About Comp Cams 918 Springs
I used them in my old camaro with no problems.
Anyways, the ones in my camaro were black with a blue stripe.
The ones that came with my thunder racing cam kit are silver without any stripes. Did I get the bad batch?
I will post some pics tomorow along with the production number.
Old Apr 20, 2010 | 08:40 AM
low2001gmc's Avatar
as i recall, pac used to make them for comp and all was well. then comp switched makers and made some black with some color stripe that were problematic. comp then came out with the black with blue stripe and those were good. comp's most recent and supposably best spring now are the silver ones which have some material improvements. hope this helps and good luck with your project, rob.
Old Apr 20, 2010 | 08:50 AM
Preston129's Avatar
Here's a quote from someone back in 07:
Originally Posted by bergenfelter
I spoke with my contact at Comp today, Chris Mays. If you have a spring batch number that is numerically less than 054168 you have the potential to have a bad set of springs. If you have a batch that is below this number, contact Chris Mays at Comp at 901-795-2400 extension 505. I just received my new springs next day air.
The problem was originally with the blue stripe ones, but most of the problems occurred around 2007...grey is the new style.
Old Apr 20, 2010 | 11:30 AM
dug's Avatar
dug
Banned
didnt have a problem with the ones in my camaro. 25k miles shifting at 6700. Hit the rev limiter regualrly.
Glad to know the grey ones are even better. Its for the tr220 .551" cam so it should be fine.
Old Apr 20, 2010 | 11:37 AM
budhayes3's Avatar
PT's Slowest Truck
Search around on LS1Tech, I've seen pictures of the new silver ones broken too...I'm going to get PAC 1218's for my LQ9 build
Old Apr 20, 2010 | 11:47 AM
dug's Avatar
dug
Banned
wtf. comp cams shouldnt be allowed to sell springs
Old Apr 20, 2010 | 01:20 PM
Jon@Texas-Speed's Avatar
FormerVendor
We've run a TON of the new 918 springs without a single issue. I wouldn't hesitate at all running them on a XE or XER lobed cam under .600" lift.
Jon
Old Apr 20, 2010 | 02:19 PM
low2001gmc's Avatar
i run pac 1218s with no issues....
Old Apr 20, 2010 | 03:04 PM
dug's Avatar
dug
Banned
Jon
thats good to know. Im just a lil paranoid cuz of issues in the past. If they break its bye bye motor. Its going in a 4.8L which everyone considers a boat anchor so if they toast the motor, its a good excuse for a LQ9
Old Apr 20, 2010 | 08:08 PM
Z'06's Avatar
What's the going rate on a set of Comp 918 springs these days anyway? You can get a set of 16 PAC 1218 springs for $122.95 at SDPC.
