Question about 03 5.3
Old Apr 23, 2007 | 10:12 PM
fillpot's Avatar
Default Question about 03 5.3
Hey guy's just bought a 03 RCSB with a 5.3 and 3.42's,about a year ago i had a 02 RCSB 5.3 with 3.73's,my question is the 02 would smoke this 03's ***,it's like night and day,I would'nt think the 3.73's would make that much of a difference,both truck's are completly stock,just looking for some input in the difference of these truck's,also the 03 is throwing a knock sensor code how bad does this effect performance.Thank's guy's any input would be a great help.THANKS!
Old Apr 23, 2007 | 10:25 PM
truckmann's Avatar
If it's throwing a KR code it is probably running on the low octane table so you timing is probably much lower than what it should be. This could be some of you the difference in power you feel along with the difference in gears. How many miles are on the truck?
Old Apr 23, 2007 | 10:54 PM
fillpot's Avatar
Old Apr 23, 2007 | 10:57 PM
gmforlife's Avatar
It has a little to do with the gears, but you could be running shitty gas or something. If they are completely stock then also it's the settings in the pcm, it might be the same 5.3 but things change from year to year. Different shift point settings, maybe added timing idk. Someone will chime in that knows more between the two year's settings.
Old Apr 23, 2007 | 11:01 PM
truckmann's Avatar
I would find out what is causing it to throw that KR code first. While that's not real high mileage for these engines or anything your cats might be starting to get plugged, especially if the truck has been running lean, that will also hurt performance. I was pleasantly surprised when I installed my headers and removed my cats at how much smoother it runs and how much less throttle is needed to cruise on the highway.
Old Apr 23, 2007 | 11:15 PM
gmforlife's Avatar
I agree, you need to find out why ur getting KR. Find out if anyone has hptuners or something in your area or if you have a friend at a dealer or something to find out what is goin on with the motor.
Old Apr 24, 2007 | 07:45 AM
I agree...the converters could be clogging up, and this will make a hefty diffrence in performance of the truck.
Old Apr 24, 2007 | 08:40 AM
blue_04's Avatar
I've heard somewhere that the 02's were the fastest stock trucks. They were less restrictive in the tune than the other years. In 03 they added in more TM or something. Somebody back me up.
Old Apr 24, 2007 | 10:04 AM
gmforlife's Avatar
That is very much possible
Old Apr 24, 2007 | 10:56 AM
zippy's Avatar
The knock sensor code is commonly from a bad sensor or bad wiring. That will command 8-10º of timing retard any time you are at wide open throttle. Fix that and you'll find that the 03' should be roughly just as quick as the 02'.
ferrellrooster
Mar 6, 2025 03:22 PM
USMCvet0311
Aug 1, 2015 07:45 AM
vmaxpro
Jul 27, 2015 10:45 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
grantpo
Jul 15, 2015 12:21 PM
