Q's about Efans, corvette servos, and a shift kit
Old Jan 3, 2004 | 03:38 PM
1LEThumper's Avatar
Default Q's about Efans, corvette servos, and a shift kit
When doing the Vette servo, there isn't anything else to get besides teh servo itself correct? Also...thoughts on installing a TransGo kit at the same time and what setup as far as springs go with the Vette servo.
Secondly....on installing the F body fans and wiring them up to the computer itself. I saw a wiring diagram on here a little while back..where do you get one of the pins for the PCM plug, and what all do you need besides some wire, the fans, a pin, and a relay?
Just trying to get a shopping list going
Old Jan 3, 2004 | 03:49 PM
agreif's Avatar
For the e-fans here is what I did, instead of getting the relay I just ordered the flex-a-lite controller, made it super simple to wire up.
Andrew
http://james.jaguar.net/agreif/fans/fanstech.htm
Old Jan 3, 2004 | 04:10 PM
abbo7's Avatar
Agreif, I really liked that write up, it will help me when I decide to drop some e-fans in my truck. One question though. Do you have it set up with the VSC controller so the fans kick on when the engine reaches a certain temp. along with having a manual on/off switch?
Old Jan 3, 2004 | 04:49 PM
agreif's Avatar
No you don't have to use the VSC, I believe there is a way to do it otherwise, with LS1Edit and possibly a relay (what the VSC basically is) but I don't know how to do it. NO you don't have to have a manual on/off switch, just something some people have, be careful if you have an OFF switch, that could get disastrous if you forgot one hot afternoon in the city.
Andrew
Old Jan 3, 2004 | 09:51 PM
1LEThumper's Avatar
Well I already have LS1 Edit.....and call me a little bit of a perfectionist but I'd rather have it hooked up to the PCM since it does allow for it....just make it look like it was factory done ya know.
Old Jan 4, 2004 | 01:57 PM
agreif's Avatar
Yeah, I agree with you, I would rather have it on Edit too, but I don't have edit so I don't know how to do that. You may want to ask James B over on Pacific-Audio, I know he knows how to do it.
Andrew
http://www.pacific-audio.com/perform...iscussion.html
X_Racing1
21
Mar 30, 2016 02:37 PM
Blackrat48
Aug 16, 2015 11:56 AM
lycominghunter
Aug 15, 2015 12:26 PM
Ammadien
Jul 22, 2015 08:50 PM
zaathur151
Jul 6, 2015 10:57 PM
