Pyrometer info
Old Dec 4, 2011 | 11:48 AM
kalikid06's Avatar
Default Pyrometer info
I had a member ask me what my experience was with a pyrometer on a gasoline engine. I wasn't sure which section to post this in but I hope this will suffice. Here is my experience with a 0-1600* F autometer pyrometer on a stock 4.8L with a rear mounted intercooled Garrett T-04E on a 5000lbs truck (I'm pretty sure a heavier vehicle will yiled higher EGT's when driving than a lighter one).
On a cold start up, the pyro would start at about 200* and increase to about 750* after about 5 minutes of warm up time. Under light throttle (granny accelerating) the pyro would gradually increase to about 1200*, hover around that point and stay there once a speed of about 60mph was reached.
With the engine warm and making a hard pull @ WOT, the pyro reading would increase at an average rate of about 50* per second. Peak temperature will dramatically depend on the duration of a WOT or full boost pull(full boost at less that WOT) The highest I ever saw the needle read was right below 1600*. That was also boosting up a hill during a hot summer day.
Shutting down. I idle through the parking lot and park the truck. Immediatley after the column went into park, the pyro would read about 900*. I'd let the truck idle down for about 30 seconds and the pyro would settle around 750*.
Now the effects of methanol. I'll make this one short. I started out with 6psi and no methanol. Then I almost doubled the boost (turned it up to 11.5psi) and added the methanol system during the same garage session. The result......My EGT's were actually slightly cooler with 11.5psi and methanol then 6psi without methanol.
This is just my experience with a pyrometer and the cooling effects methanol has on EGT's. Every setup will vary some but at the very least, this will give some baseline information on pyrometer use with a boosted gasoline engine - methanol or not.
Old Dec 4, 2011 | 11:58 AM
smokeshow's Avatar
Mod with training wheels
Good info
Old Dec 4, 2011 | 12:05 PM
Atomic's Avatar
I have a gauge for that
Is that with 100% meth or 50/50 meth/water? Water injection is quite common on diesels for EGT control.
Old Dec 4, 2011 | 12:30 PM
kalikid06's Avatar
100% methanol
Old Dec 4, 2011 | 12:32 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Just as important as the temperature is where you have your thermocouple at. IMO it should be installed directly into one of the exhaust manifold primaries just like the diesels. Some people put them after the turbine on a front mount and that is incorrect IMO.
Old Dec 4, 2011 | 12:51 PM
kalikid06's Avatar
Agreed. I mounted the pyrometer probe about 8 inches away from the #7 exhaust port - it was as close to the head as I could get it. I prefer to get the most accurate reading of EGT's exiting the engine, not the turbo
Old Dec 4, 2011 | 01:02 PM
1slow01Z71's Avatar
Sounds good, do you have any readings with your new setup? Looks pretty stout
Old Dec 4, 2011 | 01:07 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Good thread, thanks for the info! Did you ever peg your 1600* gauge?
Old Dec 4, 2011 | 01:23 PM
kalikid06's Avatar
Unfortunatly not. I never had the desire, nor the motivation, to install the pyro when I swapped to my new setup. Not to mention, I already have fuel pressure, boost, and wideband AFR on the pillar - didn't want a fourth gauge.
No. However, I did get to about 1598* on one occasion
Old Dec 4, 2011 | 01:31 PM
Whoa son, WHOA!! Close call right there!
RustyD
May 23, 2016 07:04 PM
slimchevy2
Oct 4, 2015 08:02 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
Wolftrk99
Oct 2, 2015 08:17 AM
Silver8ado
Sep 30, 2015 11:42 AM
