Putting truck in neutral
Old Jul 19, 2004 | 03:21 PM
James B.'s Avatar
Originally Posted by Yelo
When you take the transmission out of drive you are dis-engaging the front pump....
The front pump is powered by the converter hub. It turns at the same rpm as the crankshaft.
Old Jul 19, 2004 | 03:23 PM
Yelo's Avatar
are you SURE......I was explained to by the dealership that it WAS NOT (is it possble the 4L60 and 4L80 are different in the aspect ???)
Old Jul 19, 2004 | 03:25 PM
Stroker 1500's Avatar
im pretty sure as long as the engine is on there is always line presure no matter where the gear selector is
Old Jul 19, 2004 | 03:33 PM
James B.'s Avatar
Yes, I'm sure.
The only gray area here is the version of the 4L60-E used in the hybrid trucks. Option code M33. These are the ones that have an electric generator/motor sandwiched between the flexplate and torque converter. (These engine also have no conventional starter.) This trans has an electric pump in the pan to supply line pressure when the truck comes to a stop and the engine shuts off. Even in this trans the front (main) pump is driven by the converter hub.
Old Jul 19, 2004 | 05:11 PM
Tokez420's Avatar
Originally Posted by 00silverado327
My dad has this habbit of putting his car in neutral (its an automatic transmission) when at a stop light, or if stopped anywhere for more than a few seconds. He says its easier on the transmission...I was wondering if anyone knew if this is true, and why?
i do this after i brake hard...that way i dont create a hot spot on the rotor while stopped.
Old Jul 22, 2004 | 05:43 PM
SBChevrolet's Avatar
also guys with big cams and stock converters do it to keep the car from wanting to drive though the brakes and jump around
wrb002
Aug 31, 2015 12:00 PM
MileHighSierra
Jul 22, 2015 11:19 PM
black6spdz
Jul 16, 2015 01:32 AM
Breitling
Jul 6, 2015 06:39 PM
Breitling
Jul 6, 2015 04:50 PM
