Put this in the PCM forum .. thought I'd give you guys a crack at it too.
I've had reduced powermode before. I think I had the TB harness plug loose or something. Not exactly the same thing as yours since yours goes limp after it goes WOT. Its only done that once.
Do the segment IDs match between your Edit files?
Have you done a hard reset of the PCM yet? Pull the Neg batt cable then turn ignition on to start for 30 seconds. If that doesnt work, try the pos batt cable. If that doesn't work either, then go have a drink.
therock
Jul 25, 2015 09:23 AM
lxcoupe
Jul 21, 2015 02:12 AM
and hope the dealer can help me out.
