Pushrod question
Old Jan 8, 2005 | 08:43 PM
99Silver6.0's Avatar
Default Pushrod question
Im having some 317 heads milled 30 thou. How do I find out what length pushrods to use once the mill is done??
Old Jan 9, 2005 | 08:07 AM
chevymec's Avatar
Think you need the pushrod measuring tool. Never used 1 myself.
Old Jan 9, 2005 | 08:08 AM
mattrem's Avatar
You have to check the preload on the lifter when you put the heads back on. The preload should be between 60-80 thousands with the stock lifters, I think. There is alot of debate about this with the ls1 guys some say as much as 120 thousands of preload, Too much preload will kill the lifter life or blow it out. Which ever comes first. You should be close with just 30 thousands.
Old Jan 9, 2005 | 08:19 AM
sfj
im using 20 thousandths with nothing done to mine i think you should be alright i know stupid fast when he had his 5.3 did 30 and it worked fine i agree with mattrem it is borderline but ok IMHO
LTX355
Aug 31, 2015 07:21 AM
chevy6.0fan
Aug 20, 2015 07:10 PM
Bluchevypick
Aug 18, 2015 09:11 AM
USMCvet0311
Aug 1, 2015 07:45 AM
lxcoupe
Jul 30, 2015 02:42 PM
