Pushrod question
You have to check the preload on the lifter when you put the heads back on. The preload should be between 60-80 thousands with the stock lifters, I think. There is alot of debate about this with the ls1 guys some say as much as 120 thousands of preload, Too much preload will kill the lifter life or blow it out. Which ever comes first. You should be close with just 30 thousands.
lxcoupe
Jul 30, 2015 02:42 PM
