Pushing oil.
Old Sep 1, 2014 | 07:52 PM
DrX's Avatar
DrX
Default Pushing oil.
Still have a slight oil leak from the back of the valve covers, I think. Have a few drops at the back/bottom of the pan after a couple of runs. Push-in oil fill cap on the LSX valve covers also wants to blow out, so I had to make a bracket to hold it down. Diptstick pushes out a little, but the heater hoses hold it in. Running about 18.5 psi of boost. I have both valve covers vented to a breather tank, which only collects water.
What else can I do?
Old Sep 1, 2014 | 07:54 PM
LS1TRUCKGUY's Avatar
vacuum pump?
Old Sep 1, 2014 | 08:08 PM
Jason Z69's Avatar
^^^^ what he said. I think it will help. And if enough vacuum is pulled it can help a lil on ur time. It did on my friends camaro. (less pressure under the pistons will allow easier movement in the crank case.
Old Sep 1, 2014 | 08:34 PM
DrX's Avatar
DrX
Some have said I shouldn't need one, but it seems to me that I do. Don't know where I would fit one...AC delete?
Old Sep 1, 2014 | 10:14 PM
RS/SS 4.8's Avatar
10 Second Truck Club
How big are the breather holes on your valvecovers. Maybe going bigger will help? I know of some guys weld on like -10 AN and bigger fittings when venting the valvecovers.
Old Sep 2, 2014 | 07:51 AM
DrX's Avatar
DrX
The LSX covers only have 3/8" pcv ports. Previous fabbed covers had -12 fittings, but I was still having issues with them and they were not baffled.
Old Sep 2, 2014 | 09:22 AM
pittman's Avatar
I will be selling my vacuum pump soon if you need one. I just rebuilt and don't need it. It is from GZ Motorsports..they run about $800
Pitt
Old Sep 2, 2014 | 09:29 AM
Atomic's Avatar
I have a gauge for that
I had a similar problem and added 2 1/2" barbs on the driver side and a filter on the oil cap on the passenger side, it seems to be fixed now. Kept the stock pcv ports as well as a 3/8" barb in the valley cover.
Old Sep 2, 2014 | 11:18 AM
DrX's Avatar
DrX
I have no valley cover port due to lack of clearance for it.
Old Sep 2, 2014 | 11:21 AM
DrX's Avatar
DrX
Pitt
How does that pump mount?
