Pulling motor now, HELP
Old Aug 29, 2009 | 10:36 AM
02slow4.8's Avatar
Default Pulling motor now, HELP
I'm pulling the motor on my 02 Silverado right now and I can't get the engine to seperate from the trans. I know I have to get it to slide off of the pins but yanking it forward by the engine hoist pulls the whole truck. Any tips, tricks to get this thing off?? And I have gone back and made sure all trans bolts, etc are off. Thanks guys.
Old Aug 29, 2009 | 10:39 AM
00ChevyScott's Avatar
Wearin' da big hat
converter bolts are out?
Old Aug 29, 2009 | 10:42 AM
dlt76028's Avatar
This has been asked a bunch of times and usually someone misses a trans bolt. Some have 7 and some have 8.
Old Aug 29, 2009 | 10:55 AM
02slow4.8's Avatar
i took out 8 and the 3 converter bolts
Old Aug 29, 2009 | 10:56 AM
02slow4.8's Avatar
is there some kind of way like having the motor tilted up or tilted down that will help force it off the dowels?
Old Aug 29, 2009 | 10:57 AM
Coban's Avatar
Give the trans case a few good knocks with a hammer. Spend a little time knocking the area around the pins too.
Old Aug 29, 2009 | 11:02 AM
dlt76028's Avatar
Do you have a jack or jack stand under the trans? You might have the engine or trans too high or too low for each other and it's binding.
Old Aug 29, 2009 | 11:16 AM
_zebra's Avatar
makes children cry
+1 on the floor jack. i also used a pry bar all around the bellhousing just to get it started. once it's loose, it should just wiggle right out
Old Aug 29, 2009 | 11:24 AM
02slow4.8's Avatar
There is a jack under the trans with pressure on it
Old Aug 29, 2009 | 11:53 AM
budhayes3's Avatar
PT's Slowest Truck
Floor jack and pry bar
