Pulling the motor!!! Need some assistance please.
Old Apr 21, 2006 | 01:05 PM
TURBHOE's Avatar
my fuel line and cross over i just hung up on my hood. did you put your hood in the "service position"? it helps to not have to take it off.
Old Apr 21, 2006 | 01:06 PM
01Blackerado's Avatar
never knew there was a "service position" What do I need to do to do that?
Old Apr 21, 2006 | 01:07 PM
Originally Posted by Zick
Don't see why not, you should be able to flex it out of the way. If not, go to sears and get the fuel tool for like $10.
Nice!!! Thanks for the info
Old Apr 21, 2006 | 01:09 PM
white1's Avatar
On your hood hinges, unbolt teh front bolt (I think its the front one) then stand teh hood straight up and put the bolt in the other hole. On my intake, I just used a trox screwdriver and removed teh fuel rail. Just be sure you dont loose teh O ring, its a bitch when you go to crank the engine and spray everything with gas then have to find somewhere to get an O ring late at night. So I hear at least
Old Apr 21, 2006 | 01:40 PM
Thanks!!! I'll ive it a try when I get off work today!!
Old Apr 21, 2006 | 05:13 PM
TURBHOE's Avatar
yeah unbolt the hood from the hing itself, then lift the hood striaght up and put the hing up to the back hole and run the bolt through and put the nut on. you don't have to tighten it just finger tight.
Old Apr 21, 2006 | 10:45 PM
Colby 04's Avatar
That tip should go HERE
Old Apr 22, 2006 | 02:58 AM
thunder550's Avatar
High on diesel fumes
Tip has been added
Old Apr 22, 2006 | 05:18 PM
Colby 04's Avatar
Originally Posted by thunder550
Tip has been added
thanks for the pic too
Old Apr 25, 2006 | 12:51 PM
thunder550's Avatar
Hey Blackerado, did you end up getting the engine and tranny out?
