pt88 report
Old May 15, 2005 | 11:37 PM
  #41
James B.'s Avatar
Hydro-Boost works so much better than the vacuum booster. I would think the parts from an 04 or 05 SUV would swap in. As I understand it those have hydroboost from the factory now and are the only 1500 chassis that do. A vacuum booster can only charge up when there is vacuum but the hydroboost will always work.
Old May 16, 2005 | 12:11 AM
  #42
parish8's Avatar
single digit dreamer
i dont think a quick rev is going to be that big of a deal. if it turns out to be a pain i might look into the hydroboost.
Old May 16, 2005 | 12:31 AM
  #43
zippy's Avatar
i think it'll only be a pain in street racing which we both enjoy.
Old May 16, 2005 | 08:32 AM
  #44
1320Video's Avatar
Damn Jim... f'in trouble maker!
Old May 16, 2005 | 08:33 AM
  #45
cablebandit's Avatar
9 Second Club
Parish, i use a 2 step on my f-body....brake stalling gets me no boost before pushing thru the beams. On the 2-step set to 2500 rpms (and I drop timing to 1 degree) I get 3-4.5 psi. Not much difference but my best 60' times with 2 step and without are 1.57 and 1.7 so that IS a big difference. I can get higher on the 2 step for more boost once I get the air out of my lines. If that doesnt work, I will use the ebrake as well like the turbo buicks do. With Hptuners....stall up to about 1200 rpms so the truck doesnt die....have "vcm controls" up so you can click the "absolute timing" to 1 degree and then stall on up some more and watch how much more boost you get...the dropped timing adds lots of heat/boost. What i have done is drop timing to 1 degree using the "vcm controls".....get on the 2 step at 2500 rpms and look at where I am on the histogram at 2500 rpms on the 2step. Then I just edit my bin to have 1 degree of timing in a little area right where I saw it was at on the 2 step in the histogram...make sense? you could do this without a 2 step as well if you can stall it to a particular rpm everytime.
Old May 16, 2005 | 11:47 AM
  #46
Wilde Racing's Avatar
How do I change this text
I take it the cops didn't care too much about the methanol?
Old May 16, 2005 | 05:56 PM
  #47
parish8's Avatar
i might try the low timing thing. i can set something up prety easy a brake switch and the stock IAT input.
cops asked about the meth and nitrous and laptop and gtech and video camera..... then let me go.
Old May 16, 2005 | 06:21 PM
  #48
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Tell them you're a dentist (and try to look innocent about the meth, laptop, and vc).
Old May 16, 2005 | 07:08 PM
  #49
Wanted in 13 states,Parish the kid,the Omaha Silverado Desperado
Old May 16, 2005 | 07:25 PM
  #50
BigBlockChev572's Avatar
Yeah, that's it. Those "Dentist on wheels" guys. N20 to knock you out and the meth to give you that minty fresh breath.
Philip S.
