prospective cam
Old Dec 2, 2002 | 07:27 PM
Banned
Default prospective cam
do you guys think i should go for this cam (224/224 566/566) i can get it at 280 in my hands from houston. would it work well with an otherwise stock setup or what? need info please!!!!
Matt
Old Dec 2, 2002 | 07:58 PM
BigTex's Avatar
Default Re: prospective cam
Well, I think its too big. It would work fine though. Probably have a rough idle. Dont let me discourage you from doing it. Someone needs to throw a big cam in a 5.3 and see how it reacts.
Old Dec 2, 2002 | 08:05 PM
Banned
ok..say it is to big...what side effects would i see? just a rough idle...couldn't that be fixed with a few holes in the tb blade? what else might happen?
Old Dec 2, 2002 | 08:10 PM
GREGGO's Avatar
What is the LSA? There is no way you can make that work with out some pretty good tunning. Got LS1Edit yet? Is it used? Thats basically a cross on the C1/C2 cam. You would also benfit greatly from some head work and NEED a 3000 plus stall converter or your pissin in the wind. Without a converter, you truck will have NOlow end grunt at all.
Greg
Old Dec 2, 2002 | 09:26 PM
BigTex's Avatar
Side effects -
Crappy idle.
Stalling at sudden stops.
No torque.
SES lights.
Misfires.
No converter lockup because of the misfires.
Benefits -
Big power (upper rpm).
Heavy lope (if you want that).
Something no one else has done.
Old Dec 2, 2002 | 09:54 PM
really slow truck's Avatar
yep, from what i remember you already have a nitrous kit correct? if thats the case, get your tuning worked out and then spray like 125 off the line with a nice converter. might turn out good who knows <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> worth a try <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Dec 2, 2002 | 10:19 PM
Banned
so, basically what you are saying is that i should probably go with a smaller cam...that sucks cuz i could get that one really cheap, with springs and everything 220
Old Dec 2, 2002 | 11:38 PM
sleepersilverado's Avatar
i will sell you a stock 5.3 cam <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
Old Dec 2, 2002 | 11:44 PM
Banned
i have another prospective, it's a z06 cam, with springs and all....210 delivered. what kind of performance would that get me, with headers???
Old Dec 3, 2002 | 12:08 AM
oxidizr's Avatar
Moderator / Sponsor
Like the others have said...these cams may be a good deal but they don't fit your application very well. You would just need to make some necessary complimentry mods to make them work well.
The 224 cam can be a good selection matched with a good converter but would almost be a waste without doing some headwork or bumping the compression. It would have to be on a faily tight LSA (112-113) to make up for the extended duration. Tuning will be a must for "good" drivability. The shop (AAP) has done a few 111-112 LSA cams in stock displacement 5.7's which have performed well and remained resonably drivable.
The LS6 cam will make more peak but at a reasonably higher rpm. Coupled with proper tuning this could be a good swap for minor increases. Don't expect huge gains...a solid 20-25 HP may be attainable with the right bolt-ons but without a converter the peak gains will be negated or at least substantially offset by the low end loss.
