problems with ASP underdrive pulley
Old Sep 21, 2011 | 10:27 PM
Chevy_King1500's Avatar
1. Use your old bolt to install the damper and torque to 240 ft/lbs, then remove it. This is to seat the damper completely.
2. Install your new bolt and tighten to 37 ft/lbs.
3. This step is to get a reference on the front of the engine. With the torque wrench hanging at the spot where the 37 ft/lbs was achieved, reference 140° clockwise for another tightening cycle. Put a mark or a piece of tape where you need to tighten.
4. Then go another 140° from the 37 ft/lbs start point and you are now tight.
from LS1 tech
Old Sep 21, 2011 | 11:17 PM
do not use an asp udp.....ive swapped 2 of them out already on buddies trucks. not sure what it is , i guess b/c they are made of aluminum, but it will eventuallt spin on the crank....get the powerbond or trick flow udp. just my 2 cents of course
Old Sep 22, 2011 | 03:45 PM
Alpinestar's Avatar
It will be hard to get 240 ft/lbs if you don't have the tool that jams the flywheel. I had one buddy jam the flywheel with a big screw driver and another try to hold the pulley still while I tightened it. I think we hit at least 200 ft/lbs before the screw driver slipped off but its been fine for over a year
Old Sep 22, 2011 | 07:43 PM
getchusum99's Avatar
thanks for the info. "06tx4.8" so the ASP is garbage?
Vortec350ss
Jan 12, 2016 10:36 PM
wickedRCSB
Oct 30, 2015 09:45 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
old motorhead
Sep 29, 2015 08:22 PM
murderedSS
Sep 27, 2015 10:16 PM
