problems after heads and cam swap
Old Mar 17, 2009 | 12:11 AM
LS3powered's Avatar
formerly charlyroxs411 (changed 11/19/2012)
Oh, and the cyl that are missfiring are 3,5,7
Old Mar 17, 2009 | 12:31 AM
budhayes3's Avatar
PT's Slowest Truck
What does the O2 sensor activity look like, could be a bad bank 1 O2 sensor, or maybe injector ground on that side or you could have a plugged cat on that bank. Seems like all of bank1 (except for cyl 1) is misfiring...you could try swapping the O2 sensors side to side and seeing if the misfires follow...
Old Mar 17, 2009 | 01:32 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You need to check exhaust backpressure on both banks, before the cats. It sounds like a plugged cat.
Old Mar 17, 2009 | 01:35 AM
nd the diagnostic said the timmking was off
Is that supposed to be Timing?
wouldnt that explain a lot?
Old Mar 17, 2009 | 06:58 AM
white lightning SS's Avatar
I feel pretty confident you have a plugged bank one cat. Check backpressure or pull the Y-pipe off and inspect.
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
steves86ta
Jul 28, 2015 10:21 AM
4B11T
Jul 13, 2015 03:48 PM
Aboss
Jul 9, 2015 10:28 AM
