Problem w/Tune and E-Fans
Old Jan 1, 2005 | 03:23 PM
abbo7's Avatar
Default Problem w/Tune and E-Fans
I have a Nelson Tune with his e-fan harness and about every 10-15 times my truck's ignition is turned from the on to off position my e-fans still run until I turn the truck's ignition back to the on position and back to off. Does anyone else have a problem like this?
Old Jan 1, 2005 | 04:20 PM
KySilverado's Avatar
There is a setpoint in HPTuners for the PCM to contiune to run the fans if the temp is at or above a certian temp. There is also a time set for them to run. Is it possible that when this happens the truck is fairly hot. I supose a way to test would be when this happens to just let them run for a bit and see if they turn off on their own?
Old Jan 2, 2005 | 02:23 AM
abbo7's Avatar
I dont think that it is. When I turned my truck off and went into a store I came back 15 min later and the fans were still running. I was suprised it didnt run my battery dead. I am not sure what is up with it. It doesnt do it every time, but once every 10-15 times I turn the truck off.
Old Jan 2, 2005 | 09:38 AM
I'd suggest pulling out a multimeter or a test light and do some testing. Possible a sticking relay? Could still be the pcm doing what it is told to do but a very long time set in the time to run value. Would have to have edit or HP to look.
Old Jan 2, 2005 | 02:30 PM
desTRUCKtive's Avatar
Not exactly the same problem but ,my fans did this when I was disconnecting the battery. I pulled of the negative terminal (but the ground to the fans was still hooked up on my top post) and the fans went on. I thought that was wierd so I hooked it back up and the fans kept running. The only way I got them to stop was by dissconnecting the actual power that goes to the fans. It was wierd. But the thing is I have a VCS controller. Dont know maybe your wires that power the fans.
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
old motorhead
Sep 29, 2015 08:22 PM
