Problem with my truck @ idle
High on diesel fumes
Had a new problem surface today. When I start my truck cold it will die right away unless I hold the gas pedal down, in which case it will rev to wherever until I release the pedal, then it dies again.
Once everything warms up the truck will idle, but at about 400 rpm instead of the 550-600 it's supposed to be at. It runs and drives fine everywhere except at idle. No SES light, and I swapped out the MAF sensor already, no help.
Anyone have any ideas for me?
You can get throttle body cleaner at just about any parts store (comes in a spray can like brake cleaner). I use BG Induction cleaner that I get at work that's really good. You want to remove the air intake hose and open the throttle blade and spray in there real good. I usually take a rag and wipe down the throttle blade and body to get all of the carbon out. If it's really gummed up, you can remove the throttle body (or just unbolt it) and get it from both sides.
I pulled the TB off and looked, it didn't look too bad, but I will get some cleaner and do it anyway.
Got a vid of the truck idling too, in case it would help. Quicktime format, 9.25mb.
Another thought...could it be a bad idle air control valve/actuator/whatever it is?
GreyChevy
Jul 7, 2015 08:57 PM
