problem after t stat install
Old Mar 17, 2009 | 02:26 PM
JoeGibbSilverado's Avatar
Default problem after t stat install
i had my truck tuned for a 160, well i misplaced it and ran the stock tstat, no big deal, the fans stayed on, lol, get me another 160 2 days later, been a week with no probs till last night, p0128, what gives? truck isnt running rough or hot, temperature rises normal, just that irritating *** ses light. ignore it or fix it? and if fix it how?
Old Mar 17, 2009 | 03:16 PM
white lightning SS's Avatar
That code sets when the ECM does not detect that the vehicle has warmed up in the proper amount of time. It suprises me that that code did not set before. Tune the code out and be done with it.
Old Mar 17, 2009 | 05:09 PM
ss454327's Avatar
That is a LOW coolant temp code. It's typical to pop up when you change to a lower t-stat. Just have it tuned out so it doesn't pop up anymore. No worries.
Old Mar 17, 2009 | 08:52 PM
budhayes3's Avatar
PT's Slowest Truck
That's the second time that I've heard of that with the 160 stat, makes sense why it would happen. It wasn't an issue for me, although I did tell my tuner to tune for the 160 so he may have deleted that code...
Old Mar 17, 2009 | 09:26 PM
put the stock t stat back in, light went away still runs strong, oh well
Old Mar 18, 2009 | 12:34 AM
budhayes3's Avatar
PT's Slowest Truck
Why don't you put the 160 back in and have Wheatley make the necessary adjustments...I'm curious what changes get made, maybe run a little more timing, change fan settings if running efans, soften up or delete a few codes. I wonder if the cold enrichment strategy has to be altered?
Old Mar 18, 2009 | 07:04 AM
I read online that Vinci does not recommend even running the cooler thermostat. He says the motor will never get hot enough to vaporize the condensation that builds in the motor. This can damage bearings over time. I switched back to stock due to the fact a hotter lean engine is better on gas when properly tuned.
ferrellrooster
Mar 6, 2025 03:22 PM
ZONES89RS
21
Sep 24, 2015 05:58 PM
hartinclay
Aug 3, 2015 07:03 PM
zblee
Aug 3, 2015 03:45 AM
lxcoupe
Jul 21, 2015 02:12 AM
