Priming lifters before install?
Old Oct 20, 2006 | 05:31 PM
FarmerBeau's Avatar
Sexy Party Mod
Default Priming lifters before install?
Just got my new stock replacement lifters from scoggin dickey . Was just wondering if they are like old school hydraulic lifters where you have to submerge them in oil and pump them in order to prime them up before you install or do you let the motor prime them up itself? Thanks!
Old Oct 20, 2006 | 05:33 PM
LesPaul's Avatar
manual says just assembly lube when you put it all together... then just poor some oil on the valve system when done... then you should be good....
Old Oct 20, 2006 | 05:37 PM
FarmerBeau's Avatar
Sexy Party Mod
I have some comp cams old school assembly lube, that should work huh? Valve stem on the heads?
Old Oct 20, 2006 | 05:38 PM
LesPaul's Avatar
yeah any assem lube workds fine..... not just the stems... basicly with covers off you just splash oil everywhere
Old Oct 20, 2006 | 05:47 PM
FarmerBeau's Avatar
Sexy Party Mod
Ok.... How is that gonna help the lifters prime. I have been done quite a bit of work on the truck and never heard of that method. I pushed on them and they almost seem to be primed already.
Old Oct 20, 2006 | 05:49 PM
LesPaul's Avatar
oh no no no.... i didn't mean anything related to priming the lifter.... that should all be good.... just telling you what the manual says when you install new head components
Old Oct 20, 2006 | 05:54 PM
FarmerBeau's Avatar
Sexy Party Mod
Oh ok. I got it now. I was like this either im a dumbass or this Les Paul dood fell of the deep end. JFWY.
So i dont have to prime the lifter. Like i said, i got a pushrod and pushed the hell out of it and it didnt budge like it was already primed. Just curious.
Old Oct 20, 2006 | 05:56 PM
BlackGMC's Avatar
Resident Retard
I read that most guys on LS1Tech usually submerge them in Oil for awhile. I don't know which is right but it could not hurt anything.
Old Oct 20, 2006 | 05:57 PM
LesPaul's Avatar
well you should always dip them in oil....... i thought that was a given
Old Oct 20, 2006 | 06:16 PM
99Silver6.0's Avatar
Cut up a milk jug. Let them soak in oil for a while.
