PRC vs Trickflow vs AFR
Old Mar 11, 2011 | 08:11 AM
Amedee's Avatar
Default PRC vs Trickflow vs AFR
Help needed Im backed into a corner right now I was ready to order some heads had my mind set on prc and now people are saying go for trickflow and afr someone please tell me your opinons of each head and or how they perform for your builds. Thanx
Old Mar 11, 2011 | 09:12 AM
TXsilverado's Avatar
afr and trickflow will out perform the prc heads. they will also cost alot more. if i wasnt ona budget, trick flow would be my choice. but in your situation with a 5.3, i think money could be spent better in other places.
Old Mar 11, 2011 | 11:59 AM
2004SSS's Avatar
cant compare those at all man , afr and tfs are aftermarket casting while the prc are stock cnc'ed .
the prc can work great but youll see more power from the aftermarket's . The aftermarket also has a thicker deck which is good for keeping them sealed to block with boost and nitrous.
budget heads get budget results.
Old Mar 11, 2011 | 01:56 PM
Amedee's Avatar
This isn't for a 5.3 its for my 6.0
I was quoted 2350 for trickflow stage 2 assembled with pushrods is this a deal to jump on or does it seem a little too pricey?
Old Mar 11, 2011 | 07:00 PM
2004SSS's Avatar
2350 is about retail but your not giving enough info on them
iirc i paid about 2600 for my TEA TFS 6 bolt heads assembled with dual .650 springs . upgraded intake valves and inconel exhaust valves
Old Mar 11, 2011 | 08:06 PM
stock48's Avatar
9 Second Truck Club
There is nothing wrong with budget heads if you know how to port. I run factory heads and port them myself, but if I were spending over $1000.00 or going after big power it wouldn't be on a factory casting.
Texas5.3_1251
Mar 5, 2016 08:10 PM
zblee
Nov 11, 2015 12:41 AM
Velocity1
Oct 2, 2015 08:01 AM
old motorhead
Sep 18, 2015 03:33 PM
mz00516
Aug 23, 2015 12:19 PM
