Power Steering Pump?
Old Dec 28, 2003 | 05:07 PM
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by 2001si3rr@
Do you guys think this thing will fly off the front of the motor?
It could! You could get a shorter belt and tuff it out......
Old Dec 28, 2003 | 05:09 PM
2001si3rr@'s Avatar
Sounds like a plan to me, you have any idea what size belt I would need?
Old Dec 28, 2003 | 05:11 PM
BlownChevy's Avatar
blownerator
25 Year Member
Not really......you could measure it and go to the local parts store....They can look it up by size....
Old Dec 28, 2003 | 05:17 PM
Yelo's Avatar
OK...so I was wrong.....sorry about that (I ought to learn to be 100% certain before I open my mouth )
Anyone know if the 1/2 ton Rack and Pinion system can be converted over for use on the 3/4 and 1 tons ???...specifically the 2500LD that used the 1/2 ton frame ??
Old Dec 28, 2003 | 05:19 PM
2001si3rr@'s Avatar
Alright, thanks for your help BlownChevy. I'm on my way to the parts store before they close.
Old Dec 28, 2003 | 05:20 PM
BlownChevy's Avatar
blownerator
25 Year Member
Good Luck.....those guys can be idiots!
Old Dec 29, 2003 | 10:38 PM
Shortnugly's Avatar
I just snapped my pulley shaft the Sunday before last. Power steering went out and the brakes had no assist.
Two days later, I put in a remanufactured steering pump from Napa. BTW, get the one with the reservoir attached, it's a B*tch to swap reservoirs.
The next day, I snapped the second pulley shaft. I'm now on my second reman steering pump.
I'd seriously look into getting an AGR Performance steering pump and not another remanufactured. Also look at the AC Delco reman pumps if you can't swing the AGR.
But, if the truck's under warranty, the dealer's got a nice job ahead of them.
Check out the pics of both snapped pulley shafts in this thread.
https://ls1tech.com/forums/showthread.php?t=124007
Good luck with your fix.
Old Dec 30, 2003 | 04:02 PM
StupidFast's Avatar
why won't this POS idle?
dry_kill
11
Aug 28, 2015 09:53 PM
Ketis
Jul 23, 2015 12:37 PM
1320Chicken
Jul 14, 2015 10:58 PM
lxcoupe
Jul 8, 2015 05:49 AM
