Is it possible? 5.3 with 315 WHP.
Old May 28, 2015 | 06:16 PM
07NBSChevy's Avatar
Default Is it possible? 5.3 with 315 WHP.
Is it possible to achieve those numbers with a 2007 gen IV LMG 5.3 with 243 heads, 1-3/4" Arh Headers, Airaid Jr. Kit, comp cams 212/218 114 LSA cam, Blackbear Tune, 4.30 gears and 31.5" tires.
My buddy says it cant be done with those mods only. He says i wont break the 300hp mark.
Old May 28, 2015 | 06:52 PM
JordanH's Avatar
Restricted
I don't know much about cams, but I'm sure that you could be right at 300whp with the right cam, tune, and other mods you mentioned!
Old May 28, 2015 | 07:33 PM
black00chev's Avatar
Slowest turbo build ever!
Look in my sig, similar setup but im slightly milder. 300hp no problem.
Old May 28, 2015 | 10:38 PM
Vortec350ss's Avatar
It's not impossible, but slightly more cam would have helped you achieve those higher HP numbers while peaking at a higher RPM/
Old May 29, 2015 | 03:36 AM
Jake75's Avatar
should get it. I hit 380 with 243s cam headers stall...the tires may hurt you a little
Old May 29, 2015 | 07:01 AM
George C....'s Avatar
Formerly ScreamingL
Just dyno'd my jeep
It has a 2001 5.3 in it rides on 35x12.5x15s
Mods are gmt900 intake, baby thumper cam and true dual 2.5"
This combo was dyno'd on a mustang Dyno and made
Pulls were made in 3rd instead of 4th (cause of tire speed)
292/306
So yes a newer 5.3 with more compression and better heads on a Dyno jet will read higher
Old May 29, 2015 | 11:25 AM
07NBSChevy's Avatar
Thanks for the responses. My goal was to hit at least 300WHP on a mustang dyno. I would have went with a larger cam with a stall but i do tow 6500-7000lbs. I have yet to do the cam install. Im getting all the parts ordered now. 212/218 114lsa cam, dod delete kit, ls2 timing chain, correct cam sprocket, ls6 valve springs, complete engine gasket and seal kit including valve seals.
We have a $100 dollar bet that i wont hit 300hp. But we shall see. By the looks of it im seeing people around 300-320whp with a close setup to mine.
Old May 30, 2015 | 10:47 AM
turboal1's Avatar
Default 318 hp
I made 318hp/ 320tq w/26"tires small VVT Comp cam.799 heads
Old May 31, 2015 | 12:00 PM
bobfig's Avatar
imo you will.
what ever you do make sure you update this thread.
Old May 31, 2015 | 06:05 PM
gamble686's Avatar
You will be pretty close. I would guess you hit the goal. Kind of depends on the factory motor. Some are better than others.
