ported throttle body/help
Old Sep 29, 2008 | 10:52 PM
  #21
2007chevy5.3l's Avatar
rel3rd is right it does feel as if i have better throttle response. The polishing smooths out the rough texture that the aluminum has inside the throttle body bore. Plus it looks sweet when your done lol
Old Sep 30, 2008 | 10:33 PM
  #22
05RST2NV's Avatar
Originally Posted by l_kusler
Why not just buy the 90mm intake, tb and conversion harness if its that important? What does BBK Charge for a couple more mm? $370?
Good point i was thinking mine was a 75mm but your right its 78mm.. i guess its really not that bigga difference, ive been 11.1's on the stock one.
Old Oct 1, 2008 | 01:10 PM
  #23
rel3rd's Avatar
11 Second Club
Wink
I always thought big, bad throttle bodies were somewhat over-rated anyway.
With one of my other vehicles, I've been 10.24@133 (10.53@128 in vid) with a teeny-weeny 65mm throttle body and a smallish (for 500+rwhp) 80mm maf meter.
I think the LS style intakes are much more of a problem than the throttle bodies...
http://www.youtube.com/watch?v=TcJi1kn3Shg
Old Oct 1, 2008 | 01:48 PM
  #24
AdioSS's Avatar
12 Second Club
Did you try a larger TB and MAF in that Stang?
Are there any differences in porting a cable driven T vs a DBW TB?
Old Oct 1, 2008 | 02:12 PM
  #25
rel3rd's Avatar
11 Second Club
80mm maf is about the biggest there is/was when I had that car.
I did try 65, 70 and finally a 75mm throttle bodies in the 6+ years I had that car. No difference in ET, MPH or Dyno numbers, but I did actually lose some noticeable (when locked in OD at cruise speeds) low end with the 75 on there...
Same issue on another Ford I owned, after that one. Everyone always seemed to be of the opinion that you couldn't over intake or over throttle body an engine, but my last Mustang (before I returned to my GM roots ) lost noticeable bottom end torque as well. From 4000 rpm launch it wasn't noticeable though.
http://www.fquick.com/images/vehicle...jpg?1204479450
As you can see in the linked specs above, I had 65mm TB and 73mm MAF and shortly after ran 75mm TB, 80mm MAF and a much better flowing intake...The car gained nothing, but lost low end torque big time. It's almost like it's the complete opposite of the LS based vehicles. I keep reading that nobody claims to lose any low end with the big 90/92mm TB's and matching intake, but that isn't the case on any car I've ever owned up to this point...and there's been MANY.
Old Oct 1, 2008 | 02:55 PM
  #26
nonnieselman's Avatar
14% sounds about right for TPS voltage at idle, I've never seen a TPS at 0%
Im a dummy... i was talkin about my truck and my buddys TA... Cable TB....
natejk
Nov 15, 2016 08:05 AM
FlyingLow
Nov 24, 2015 10:05 AM
OHsixLS3
Sep 25, 2015 11:20 AM
mpal
Sep 18, 2015 09:12 PM
bisqikss
Sep 8, 2015 03:35 AM
