ported throttle body/help
#21
rel3rd is right it does feel as if i have better throttle response. The polishing smooths out the rough texture that the aluminum has inside the throttle body bore. Plus it looks sweet when your done lol
#22
Good point i was thinking mine was a 75mm but your right its 78mm.. i guess its really not that bigga difference, ive been 11.1's on the stock one.
#23
With one of my other vehicles, I've been 10.24@133 (10.53@128 in vid
) with a teeny-weeny 65mm throttle body and a smallish (for 500+rwhp) 80mm maf meter. I think the LS style intakes are much more of a problem than the throttle bodies...
http://www.youtube.com/watch?v=TcJi1kn3Shg
#24
I always thought big, bad throttle bodies were somewhat over-rated anyway.
Are there any differences in porting a cable driven T vs a DBW TB?
#25
I did try 65, 70 and finally a 75mm throttle bodies in the 6+ years I had that car. No difference in ET, MPH or Dyno numbers, but I did actually lose some noticeable (when locked in OD at cruise speeds) low end with the 75 on there...
Same issue on another Ford I owned, after that one. Everyone always seemed to be of the opinion that you couldn't over intake or over throttle body an engine, but my last Mustang (before I returned to my GM roots
) lost noticeable bottom end torque as well. From 4000 rpm launch it wasn't noticeable though.
http://www.fquick.com/images/vehicle...jpg?1204479450
As you can see in the linked specs above, I had 65mm TB and 73mm MAF and shortly after ran 75mm TB, 80mm MAF and a much better flowing intake...The car gained nothing, but lost low end torque big time. It's almost like it's the complete opposite of the LS based vehicles. I keep reading that nobody claims to lose any low end with the big 90/92mm TB's and matching intake, but that isn't the case on any car I've ever owned up to this point...and there's been MANY.
#26
