Popping noise under cab
Old Jun 2, 2004 | 10:07 AM
SuthernFlames316's Avatar
Default Popping noise under cab
Got a popping noise under my feet when i am driving. 5.3ExCab
Old Jun 2, 2004 | 10:11 AM
marc_w's Avatar
How many miles on it? Do you lube the front end regularily?
The last few GM trucks I've had that have done this, all had bad ball joints.
Old Jun 2, 2004 | 10:18 AM
Well, I have a 9 inch lift on it. Where do you lube it at. The last this happened it was my cab bolts. I tightened them and it stopped. But this time is still does it. I have about 102K
Old Jun 2, 2004 | 10:49 AM
WaitinToDrag's Avatar
i have a popping noise like that also. especially when i drove over minor bumps and brick roads and uneven surfaces
Old Jun 2, 2004 | 11:00 AM
MacADaYear's Avatar
Me too but mine comes more front the front of the truck. Its coming for the springs I think and their seats. I think the older trucks had a problem with this "popping" and might be fixed by some kind of different rubber seat for the springs.
Old Jun 2, 2004 | 02:29 PM
hink9's Avatar
there is a crossmember that bolts together on those trucks, it right underneath the oil pan, if you tak that out, clean all the under coating off, and take a dremel clean up the holes, reinstall it then tighten super tight it will probablly be gone. ive seen this on alot of vehicles, all of them were stock though
Old Jun 2, 2004 | 05:05 PM
yeary03SS's Avatar
Do you have nerf bars? I had a popping noise drive me crazy because one of the bolts that connected the strut to the frame had some play (maybe an 1/8" or so) in it and kept banging the frame every time the body of the truck rocked. I just wrapped some electral tape (redneck engineering) around the bolt and it acts as a cushion and has been fine since.
Old Jun 2, 2004 | 07:06 PM
marc_w's Avatar
Sounds like there is a lot of places noises come from.
Another one that drove me nuts for MONTHS - loose hood hinge bolt on the passenger side of the truck. I thought it was anything from front end components to door hinges to shocks.
projectnightcrawler
Sep 30, 2015 10:49 PM
97aztecgt
Sep 10, 2015 05:07 PM
tgui
Sep 9, 2015 04:55 PM
screaminian47
Sep 7, 2015 08:20 PM
hackrst
Sep 2, 2015 05:27 PM
