Plus a thermostat?
Old Jul 25, 2003 | 11:41 AM
StealthSierra's Avatar
Default Plus a thermostat?
Since most of you guy have some kind of ECM program or programmer, I have a question for those of you with hypertech PP3's. Besides running cooler, does a lower temp thermostat help any performance wise along with the pp3, or is this one of those things with less than a tenth improvement?
Old Jul 25, 2003 | 01:20 PM
Flyer's Avatar
Default Re: Plus a thermostat?
I can tell a noticable difference when my temp gauge is down around the mark halfway between what it calls 160 (actually 100) and 210, which would means the engines running around 160-170. In traffic or hot days when it raises up, I can tell it doesn't feel as peppy as I think it should.
Old Jul 25, 2003 | 01:23 PM
BigKID's Avatar
Are you refering to the setting on the Hypertech or acutally installing a cooler thermostat? Lower engine temps with the cooler thermostat creates a cooler intake charge thus allowing you run a leaner, more agressively timed tune before detonation occurs. Thru reading my pcm with edit, I couldnt tell that the thermo setting in the hpp changed any setings in the computer.
Old Jul 25, 2003 | 02:46 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
I didn't feel ****.
SlvrSierra4.8
Oct 1, 2015 09:39 PM
ZONES89RS
21
Sep 24, 2015 05:58 PM
Shotguntommy
Sep 15, 2015 05:24 AM
Droptoplt1ta
Aug 19, 2015 07:34 PM
ou812sm
Jul 18, 2015 01:12 PM
