Plug/Gap choice
Old Dec 21, 2015 | 10:32 PM
Suburbazine's Avatar
Default Plug/Gap choice
I've been using NGK plugs and can't hit the sweet spot. TR5/6 Projected plugs. TR5 gets heavy detonation at high RPM, TR6 gets fouling and slight detonation on hot days. TR6 runs better than TR5 hands down, but I'm running a .035" gap due to compression and HP output (is that right?). Is there some magic number gap or some particular type I should be using?
I should note the fouling issue started when I went to a 160*F t-stat (detonation was worse with 180*). I'm guessing the engine is running a bit too cool (dead on 165*F) or I'm just running the wrong plug/gap.
Static compression is 13.89:1
Dynamic compression is 12.57:1
Octane level 93 or higher
Old Dec 21, 2015 | 11:45 PM
GMCtrk's Avatar
Sounds like an octane issue, not a plug issue to me.
Old Dec 22, 2015 | 07:57 AM
George C....'s Avatar
Formerly ScreamingL
How the hell is your compression at 13.9?
Alos past 11.5 is race gas territory
13.9 on pump should have a 7 or 8 series
Old Dec 22, 2015 | 08:44 AM
Atomic's Avatar
I have a gauge for that
Yea I was about to say you need a 7 plug in there at minimum with that high of comrpession. Try closing the gap down to 0.028-0.030. What fuel are you using?
Old Dec 22, 2015 | 09:17 AM
Vortec350ss's Avatar
Also the DCR seems too high as well. You need to use cam specs at .005 to calculate DCR, not .050... did you do that right?
Old Dec 24, 2015 | 09:04 PM
Ehh...it's not right. I used the incorrect head gasket thickness (.030 is wrong).
SCR: 12.99
DCR: 11.76
Wallace Racing: Dynamic Compression Ratio Calculator
ABDC is 43.8*
Bore is 3.898"
Stroke 3.622"
Rod length 6.125" (I think that's what was put in)
862 heads milled ~.065"
Deck height -.010"
Head Gasket thickness .051"
Flat pistons with valve notches
yes it's a super close fit lol.
Cam card:
http://imageshack.com/a/img905/5862/8Jtj1w.jpg
I am running either a straight E85 (E70 this time of year) or 93 cut with VP110 (ratio dependent on what I feel like spending )
Old Dec 24, 2015 | 09:23 PM
Formerly ScreamingL
Br7 is choice id run
Old Dec 25, 2015 | 02:25 PM
splinter's Avatar
41-104 ACDelco iridium that are OE fitment on ZR1, CTS-V et al
inexpensive, too:
Amazon.com: ACDelco 41-104 Professional Iridium Spark Plug (Pack of 1): Automotive Amazon.com: ACDelco 41-104 Professional Iridium Spark Plug (Pack of 1): Automotive
Old Dec 25, 2015 | 02:32 PM
dsmmace's Avatar
What about timing advance?
Old Dec 25, 2015 | 03:08 PM
03sierraslt's Avatar
inexpensive, too:
$7 a piece inexpensive?
