Plug/Gap choice
I've been using NGK plugs and can't hit the sweet spot. TR5/6 Projected plugs. TR5 gets heavy detonation at high RPM, TR6 gets fouling and slight detonation on hot days. TR6 runs better than TR5 hands down, but I'm running a .035" gap due to compression and HP output (is that right?). Is there some magic number gap or some particular type I should be using?
I should note the fouling issue started when I went to a 160*F t-stat (detonation was worse with 180*). I'm guessing the engine is running a bit too cool (dead on 165*F) or I'm just running the wrong plug/gap.
Static compression is 13.89:1
Dynamic compression is 12.57:1
Octane level 93 or higher
SCR: 12.99
DCR: 11.76
Wallace Racing: Dynamic Compression Ratio Calculator
ABDC is 43.8*
Bore is 3.898"
Stroke 3.622"
Rod length 6.125" (I think that's what was put in)
862 heads milled ~.065"
Deck height -.010"
Head Gasket thickness .051"
Flat pistons with valve notches
yes it's a super close fit lol.
Cam card:
http://imageshack.com/a/img905/5862/8Jtj1w.jpg
I am running either a straight E85 (E70 this time of year) or 93 cut with VP110 (ratio dependent on what I feel like spending
41-104 ACDelco iridium that are OE fitment on ZR1, CTS-V et al
inexpensive, too:
inexpensive, too:
inexpensive, too:
Amazon.com: ACDelco 41-104 Professional Iridium Spark Plug (Pack of 1): Automotive
inexpensive, too:
