please help!!!!!!!!!!!!!!!!! timming is drop
Old Dec 24, 2005 | 09:27 AM
TURBHOE's Avatar
Default please help!!!!!!!!!!!!!!!!! timming is drop
ok i got some weird problems going on with my truck i drove this thing 17-1800 mile striaght it drove hard and strong the whole way back to arkansas. well yesterday i fire it up and and start to drive and when you go up hills and put a heavy load on it you can watch the timming go up and down it will climb the hill at a strong say 18* the all the sudden drop TO 1 or 2* wtf is wrong if you try and hammer it it will just bogg and won't go at all looses all timming. please help and what does it sound like if a lifter is not pumping up becouse i got this weird tick and its not pistons slap and i pulled the plug wires one at a time and its a spun bearing. so what else could it be i don't believe its a loose rocker its too queit.
Old Dec 24, 2005 | 01:30 PM
Richard@WCCH's Avatar
FormerVendor
Probably should remove the valve covers and look for a broken rocker arm needle bearing or a broken spring. Perhaps someone else can chime in about your timing issues. It seems like the two things might be related.
Good luck,
Richard
Old Dec 24, 2005 | 01:51 PM
rcsb4.8to6.0's Avatar
i had something similiar happen to me on the way home from a trip. the truck made a strange ticking noise and alot of power was lost, also the engine was running real rough. so i pulled the valve covers off and it turned out to be a broken valvespring.
Old Dec 24, 2005 | 09:18 PM
TURBHOE's Avatar
well i'll check'em but i found the timming problem. i was pulling some stuff from a cadilac stock tune for the cts-v and i used the means best timing table from it well today i load an old tune and it striaghtend out and i looked to seee what was couseing the problem between the tunes and well the cady means best timing i retarded at like 1800 rpm and 64 map i think the timing is like 22-24* well at 1600rpm and same map its freaking 5 so if your inbetween then it will jump back and forth and suck ***. this is the only thing i could find.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
USMCvet0311
Jan 16, 2016 06:04 PM
Gadgetized
Oct 22, 2015 09:06 AM
smok'nZ
Oct 6, 2015 01:14 PM
twake_410
Sep 25, 2015 10:09 PM
