Please Explain the Torque of Crank Bolt
Old Aug 11, 2006 | 02:15 AM
PappyDan's Avatar
Tribe Shaman
I see no one really read what you had to say.
so I will stand out from everybody else.
NO YOU DO NOT NEED A NEW CRANK BOLT.
if you are going to pin the crank with a pin kit then your fine, your old crank bolt will work just fine.
the pins will hold the balancer in place and keep it from moving.
just torque it down with the impact and your set.
Old Aug 11, 2006 | 05:31 AM
parish8's Avatar
single digit dreamer
yeah, i see you standing out allright. did you read the first post? he was asking how everyone else does it. not just if he needs a new bolt.
Old Aug 11, 2006 | 07:28 AM
Moddoo's Avatar
Originally Posted by parish8
i just hit it with the 250ft/lb impact till it stops moving and then for another 5 sec or so. i do use a new bolt everytime. definately not factory procedure but so far so good.
Same here
(fingers crossed)
Old Aug 11, 2006 | 02:39 PM
Thumbs up
Thanks guys. Since the pin kit comes with a new bolt, that part is taken care of. I'll see if I can get to that 140* mark with my dads 1" drive ratchet and sockets. If not, then I'll try a cheater bar on top of the 1" drive ratchet handle. If that don't work, the impact gets to take it the rest of the way till my marks line up.
I'll be sure to make it happen either way.
Jim
Old Aug 11, 2006 | 03:13 PM
FarmerBeau's Avatar
Sexy Party Mod
5 bucks says you cant hit 140*
Old Aug 11, 2006 | 04:00 PM
Wink
I'll be sure to call you down to Houston the day the pulley goes back on.
I'll take that 5 bucks. The air gun will get it to the 140* mark one way or another. The air gun I have, isn't from Sears. It'll snap that crank bolt if I tried.
Still wanna bet??? If so, I'll have to ask you to ante up the stakes.
Jim
Old Aug 11, 2006 | 04:11 PM
NOSjohn's Avatar
Restricted User
I always use a new bolt but it's a matter of choice, they are less than $5. Tighten as close to 240ft./lb. as you can get ...or do as Parish recommended w/ a air gun.
Old Aug 11, 2006 | 04:45 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
This is what I have done but reusing the same bolt 4 times and not a problem yet.
Old Aug 11, 2006 | 04:47 PM
No wonder you engine doesn't work!!!
Jim
Old Aug 11, 2006 | 04:51 PM
1slow01Z71's Avatar
Jim
Yeah the crank pulley really hurt my motor
