Please critique my setup truck guys.
Hey guys, I most frequently post on ls1tech but since this I have a truck question, I thought I would post here. I want an honest opinion from you guys concerning driveability, estimated rwhp, and 1/8 timeslips. Also, if you would kindly critique the setup and tell if the combo matches well or if I should change some things to have the best matched setup. I know you guys are going to laugh at the intake but it seems to work.
05 ECSB, 5.3, 2WD, 46k miles
Bullydog CAI (from a diesel i guess??? I didnt buy it or put it on there, was already there)
Pacesetter LT's with ORY into a 3" single inlet dual out muffler
Yank 3200 (cant remember the series but its 2.2STR), vette servo, big cooler
4.11/G80
MSD wires, NGK TR5's
Nelson tune (still have service engine light and occasional shift issue)
_____
Things to be bought with recently received scholarship money(as in this week):
TR 220/112 kit
MT ET Street 28/11.50/17
nitrous kit (still researching size and mfg. Recommendations please, and yes ive read 1000's of threads on this already and they all sound the same. FYI, Im a nitrous dummy)
dyno tune @ an established LS1 shop.
Here's the deal. Truck runs ~9.7-.9 with 2.2 60' currently. Im shootin for 7's if possible. Thanks in advance guys.
4.11/G80
_____
TR 220/112 kit
id get some sort of aftermarket limited slip, like a eaton LSD or a detroit trutrac.
may need a built trans for the nitrous.
i reccommmend the nitrous outlet truck throttle body plate kit in a 100-150 shot or the HSW plate kit in same size shot.
On another note, are those plates compatible with the 05 throttle body? and as far as the trans, I am going to run a window switch and hope for the best. If it fails, the trans will be replaced with a upgraded unit then.
And last of all, I know this is a nitrous neverending debate, but would you run a wet or dry kit (150 max)? Remember, im N20 impaired.
id probably add some apillar or elsewhere gauges( fuel press. nitrous press. and wideband AFR)
i will say that that cam (TR220 on 112) took bluecajun5.3 to 12.5s in the 1320 with stock heads and intake manifold NA
