pinion angle shims? vibration after pulley/drop
Old Dec 21, 2004 | 11:09 AM
O3GMC's Avatar
12 Second Club
Default pinion angle shims? vibration after pulley/drop
Just installed a new drop kit - swapped out the drop leafs for hangers+shackles, and now the rear is just slighly lower than it was. Also, I just installed the 3.25 pulley, and I'm seeing 9.0 psi at about 3/4 throttle (I know, sounds high - not 100% sure its correct) - and haven't even gone WOT yet because I'm getting some "low pitched" vibration which I think might be the pinion angle (from being lower and more power twisting torquing the rear)
Right now the rear end lines up just about perfect with the driveshaft, and I'm told it is supposed to be pointed down slightly, so when that power hits, it will twist and line up with the d/s. What angle shims do I need? Belltech sells anywhere from 1 to 6deg
Old Dec 21, 2004 | 11:33 AM
Flyer's Avatar
I know this problem ... I started with 3* I think and ended up going for some spring clamps. I put them in the front which also pulled the rear down some, but it also pointed the pinion up a little too.
As for which degree shim you need ... that depends on how bad your abgle is now.
Old Dec 21, 2004 | 02:29 PM
Ryan23silverado's Avatar
in the end, you want your pinion to be -2* (nose pointing toward the ground)
Old Dec 21, 2004 | 02:37 PM
chris99gmc's Avatar
me to... after my flip kit I needed at least a 3* and that's the only one I could find, so I went with it and got rid of 90% of the vibration. Adding shims is a pain in the ***... feels like you are re-doing the whole drop again.
and I can't tell you what shim you need, cuz everyone's truck is different... My advise is to get an angle finder and measure it.
Old Dec 21, 2004 | 02:57 PM
O3GMC's Avatar
12 Second Club
thanks for the info - exactly what I need to know
Tigger Welder
Oct 1, 2015 08:41 AM
twake_410
Sep 25, 2015 10:09 PM
97_ek
Sep 23, 2015 09:16 PM
03chevytruck
Sep 10, 2015 10:18 PM
