Pickin Brains
Hey guys just wanted to get some educated info/opinions on a motor build for my vehicle. I currently have a lifted sierra 1500 ext cab short bed with
5.3 stock engine
4l60e trans
4.56 front and rear diffs
37" tires
I believe the GVWR is around 6000
Looking for some info on a decent build that i can achieve around 450hp fuel injected with around $6k. Should i stroke the 5.3? use ls2? ls3? internals?
I have experience with top end components, but where i get fuzzy is the bottom end internals as i haven't spent a whole lot of time there so any theories, know how, or detailed info would be very appreciated.
The reason I'm doing this is because I have quite a few miles on the engine as its a 5.3 and its been pushing 37's and 20 inch wheels for quite a while now, still goes A to B fine but its getting tired and i would like to put together my own engine with some more guts.
thanks guys!
5.3 stock engine
4l60e trans
37" tires
thanks guys!
if it were me and it was once, I went with a 6.0/4L80.
I did all mine for just under 5,500. Its night and day. well worth the swap
https://www.performancetrucks.net/fo...s-list-513912/
I did the 5.3/60 thing for a couple years and recently went 6L/80E and wish I would have done that from the start.
heavy trucks need the cubes and heavy trucks are hard on transmissions so start with a solid plateform and go from there.
I have spent a lot of money on setups over the years so just trying to help
sounds good. did you guys get an 80e out of a junkyard and rebuilt it? im finding remanned ones from GM cores on the web for around 2.7k-3k
claiming to be built for 4x4, 750hp and whatnot. texas speed also has a 370cid block with the rotating assembly in it, which is probably more to my benefit for 3.4k i believe.
