Phamspeed
Old Mar 29, 2005 | 01:44 PM
  #21
Wow, Rick that is beautiful. Do all the hot parts come in that coating? And if so could you get the charge pipes coated like that as well instead of the black? What about a mount for a BOV though?
Old Mar 29, 2005 | 02:07 PM
  #22
F8L Z71's Avatar
Just keep in mind that those $2300 turbo "kits" don't include ANY fuel system upgrades nor does it incluse an incterooler. It's a great price but if you add all the stuff that you get with the Livernoise, Cmotoring, and STS (upgrade kit) kits you will end up paying similar prices. $5k seems like the realistic minimum for a full blown turbo kit.
  #23
LivernoisMotorsports's Avatar
LS1TECH, Trucks, Modmotor Sponsor
2002yroneformula, the contents of the normal kit are listed below, however if you wanted everything coated the same color as the hot parts I could have that arranged. We could also come up with a mount for a BOV (at an additional cost).
The kit is complete and includes:
  • Polished Garrett Turbo
  • Black Powder Coated Inlet Tubes
  • Ceramic Coating on Hot Parts
  • 42 lb Injectors
  • 3 Core Air-to-Air Intercooler
Dual 4 into 1 Tubular Headers w/ 1 5/8" primaries, 1/2" Laser Cut Header Flanges, 2 1/4" Cross Over, 3" Down Pipe, Powder Coated Inlet Tubes, All V-Band Connections, High Quality Silicone hoses w/ Aircraft Grade SS clamps, Tial 38mm Billet Wastegate, and complete detailed instructions.
* Bolt-on Installation; NO SHEETMETAL CUTTING OR WELDING required! Works with factory electronics.
The Battery, A/C, Power Steering, ABS, etc.. remain in the factory locations, so you could put your car back to stock, very easily at any time.
Thanks,
Rick
Old Mar 29, 2005 | 02:38 PM
  #24
What $2300 kits, what are you talking about?
Old Mar 29, 2005 | 02:42 PM
  #25
F8L Z71's Avatar
I'm sorry, was it $2800??
Old Mar 29, 2005 | 02:55 PM
  #26
kbracing96's Avatar
There for the f-body cars
Old Mar 29, 2005 | 06:12 PM
  #27
Crazy's Avatar
And how much would a kit like 2002yroneformula is describing (kit w/ a GT-67, BOV, etc.) run?
Old Mar 29, 2005 | 06:21 PM
  #28
I definately want to know. Cause I was considering buying a new set of LT's this summer but don't wanna drop the money on those if I'm going with a turbo.
Old Mar 29, 2005 | 07:12 PM
  #29
I would say the turbo upgrade would be $500, plus you would need larger injectors (55#) $350, plus fab time and cost of the BOV. Do you have a BOV that you would like to use in mind?
-Rick
Old Mar 29, 2005 | 07:30 PM
  #30
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
BOV
