Phamspeed
#22
Just keep in mind that those $2300 turbo "kits" don't include ANY fuel system upgrades nor does it incluse an incterooler. It's a great price but if you add all the stuff that you get with the Livernoise, Cmotoring, and STS (upgrade kit) kits you will end up paying similar prices. $5k seems like the realistic minimum for a full blown turbo kit.
#23
LS1TECH, Trucks, Modmotor Sponsor
2002yroneformula, the contents of the normal kit are listed below, however if you wanted everything coated the same color as the hot parts I could have that arranged. We could also come up with a mount for a BOV (at an additional cost).
The kit is complete and includes:
Dual 4 into 1 Tubular Headers w/ 1 5/8" primaries, 1/2" Laser Cut Header Flanges, 2 1/4" Cross Over, 3" Down Pipe, Powder Coated Inlet Tubes, All V-Band Connections, High Quality Silicone hoses w/ Aircraft Grade SS clamps, Tial 38mm Billet Wastegate, and complete detailed instructions.
* Bolt-on Installation; NO SHEETMETAL CUTTING OR WELDING required! Works with factory electronics.
The Battery, A/C, Power Steering, ABS, etc.. remain in the factory locations, so you could put your car back to stock, very easily at any time.
Thanks,
Rick
- Polished Garrett Turbo
- Black Powder Coated Inlet Tubes
- Ceramic Coating on Hot Parts
- 42 lb Injectors
- 3 Core Air-to-Air Intercooler
Thanks,
Rick
#24
#28
Originally Posted by Crazy
And how much would a kit like 2002yroneformula is describing (kit w/ a GT-67, BOV, etc.) run?
#29
I would say the turbo upgrade would be $500, plus you would need larger injectors (55#) $350, plus fab time and cost of the BOV. Do you have a BOV that you would like to use in mind?
-Rick
-Rick
