Performance needing help
Old Sep 17, 2012 | 04:38 PM
2006cory's Avatar
Default Performance needing help
iv got a chevy 2006 scsb! I had a 5.3 slightly built! Moods: bored 30 over/flat top pistons! heads: 3 angle valve job with pac racing springs .600 lift along with 7.4 crom molly push rods! Cam: is a comp.cam 212/218 557/563 lsa115! stock bottom end but freshend up! Induction is a k&n intake with a 3/4 throtal body spacer! Exaust is long tubed headers to a x pipe to flowmaster40s dumped bf the axel.. built 4l60e shift kit and 3500 stall! Rearend has a posi unit and 3.73!! & on,my 265/35/22s I made 324rwhp/364rwtq! Will a cam help me get more out my truck? Bc the cam came out my slightly modded 4.8 and I put it in my 5.3!! Yall think my cam is to small? & what cam should I go with! Please help need info!
Old Sep 17, 2012 | 06:19 PM
darnie's Avatar
Originally Posted by 2006cory
iv got a chevy 2006 scsb! I had a 5.3 slightly built! Moods: bored 30 over/flat top pistons! heads: 3 angle valve job with pac racing springs .600 lift along with 7.4 crom molly push rods! Cam: is a comp.cam 212/218 557/563 lsa115! stock bottom end but freshend up! Induction is a k&n intake with a 3/4 throtal body spacer! Exaust is long tubed headers to a x pipe to flowmaster40s dumped bf the axel.. built 4l60e shift kit and 3500 stall! Rearend has a posi unit and 3.73!! & on,my 265/35/22s I made 324rwhp/364rwtq! Will a cam help me get more out my truck? Bc the cam came out a stock 4.8 & I put it in my 5.3
yes.......
Old Sep 18, 2012 | 06:36 PM
2006cory's Avatar
I know the 220r cam is a great combo for a stock 5.3 & should I go with that cam or some diffrent cam?
Old Sep 18, 2012 | 07:01 PM
jrmchevyman's Avatar
With all that work done to your truck and a 3500 rpm converter you could go quite a bit more than a 220/220 if you wanted. What do you want to shift at? I would probably get something in the mid 220's range, and you could very easily do it without any low end loss..
Maybe try to get someone to custom spec you a cam?
Id get something like a 226/226 or 228/228 or maybe a split pattern with a mid 220's intake duration and a high 220's exhaust duration.
If you want to use the same springs, you'll have to keep the springs .600 max lift in mind.
Old Sep 18, 2012 | 07:15 PM
Bama2door's Avatar
I just got too excited to even post a helpful comment because of all your !!!!!!!
Old Sep 18, 2012 | 07:29 PM
darnie's Avatar
alot depends on what u wanto do with the truck.... 220- 224 should be ok for DD use after that ull be cutting into the street manners
Old Sep 18, 2012 | 09:11 PM
2006cory's Avatar
Its a dd. And my rev. Is set at 6800rpm! An I do wount to keep my springs..
Old Sep 18, 2012 | 09:36 PM
2006cory's Avatar
Old Sep 18, 2012 | 10:21 PM
If you're set on keeping your valve springs you can go with the tr224 its a good sized cam and not too much lift for your springs.
Old Sep 19, 2012 | 07:59 PM
2006cory's Avatar
What type of 224s r there
