? for people with transgo experience
Old Feb 20, 2004 | 06:32 PM
jlwz71's Avatar
Question ? for people with transgo experience
Okay I have the transgo kit in my 4L60e. My mods are as follows, Crane cam ported heads, shortie headers, intake, exhaust, stock converter and LS1 edit. I have a few others but anyway right now I have 2 washers in the 1-2 accumulator with the vette servo. I am leaving one hell of a strip of rubber on my 1-2 shift. This is with 33 inch tall tire. This can't be good on parts. I am looking for a very firm shift without laying rubber at 1/2 throttle. I know I need to take out some washers but how many do you guys suggest? Just leave one or take out both of them. I only want to have to drop the pan once. Thanks for the help guys.
Old Feb 20, 2004 | 08:48 PM
ThunderZ28's Avatar
12 Second Club
go no washers and buy a billit servo. this will give you a quick clean shift.
if you dont have a servo you might want to try 1 washer.
just my .02
and yes barking the hell out of the tires in second is not good. it will last only so long. trust me i know (9 transmissions later )
Old Feb 20, 2004 | 10:09 PM
gonzo 6.2's Avatar
Sounds like your gut is telling you that it's shifting harder than it should be, and it's just a matter of time.So at light and medium throttle it slams,how about WOT? does it still slam or is it softer?You might want to put a gauge on this trans in case you have to much line pressure.You got a .500 boost valve? or did someone tweek the force motor adj.?
Old Feb 20, 2004 | 10:22 PM
jlwz71's Avatar
At wot it will lay rubber. The 1-2 meduim is the bark. I have the .500 boost valve and the force motor has never been touched. Stock line pressure also. I was just wanting opinions on what people have done with theres. I will probably take both washers out. I don't need to impress people with a hard 1-2 shift.
When I get a converter I will put the washers back in but for now I beleive I will play it safe. I have already rebuilt this bitch once.
Old Feb 20, 2004 | 10:29 PM
gonzo 6.2's Avatar
What i have seen in the past was the rev boost inner valve installed backwards and this will cause extreme pressure at light and medium throttle bone jarring shifts and then be soft and mushy shifts at WOT.Yours doesnt sound that extreme.Have you had a manual gauge on it to watch main line pressure?
Old Feb 20, 2004 | 10:33 PM
ThunderZ28's Avatar
12 Second Club
yeah mine tamed down alot after i put in the stall
Old Feb 21, 2004 | 03:45 PM
XLR8NSS's Avatar
Adkoonerstrator
I wouldn't really recommend a shift kit without a stall. The stall allows the transmission to shift quick/hard with a shift kit and keeps the shock from breaking stuff.
I had two washers in my car and that thing was crazy until I got the stall in. Just light throttle and the damn tires would break loose shifting into second. BTW, that's not fun on wet roads.
Old Feb 21, 2004 | 04:06 PM
onyx's Avatar
14 Second Truck Club
i wanted to get the HD kit because i heard it was better for our trannies... any input on the HD kit?
Old Feb 21, 2004 | 04:48 PM
ThunderZ28's Avatar
12 Second Club
thats what i have in mine, wouldnt go any other way
Wolftrk99
Dec 3, 2015 08:12 PM
Gadgetized
Oct 22, 2015 09:06 AM
JordanH
Oct 3, 2015 03:59 PM
blackedoutchevy22
Oct 1, 2015 08:07 PM
