PCV valve - whats with it?
Old Jul 18, 2007 | 11:34 AM
03GMC's Avatar
Default PCV valve - whats with it?
So I pulled my PCV valve this morning and all it isnt like others I've seen. It doesnt have the little piece in it that moves just a small hole. Looks cheesy. Should I put a regular one in my truck?
It had a little black junk on it that I cleaned out with brake cleaner and its looks new now.
Old Jul 18, 2007 | 11:45 AM
budhayes3's Avatar
PT's Slowest Truck
That's called a "fixed orifice" PCV valve, it's GM's re-designed PCV that's intended to help with oil consumption. You should be able just to clean it and be fine. FWIW, I replaced my original spring and plunger style PCV valve with one of those and it still sucked quite a bit of oil. Once I installed an AMW catch can, the pcv system made an annoying whistle...I re-installed the old style PCV and the noise went away. Bottom line, the PCV system will still suck some oil either way, but the re-designed valve is "supposed" to help.
Old Jul 18, 2007 | 08:16 PM
TXsilverado's Avatar
i just put the redesigned pcv in my truck last week. hopefully it helps.
Wolftrk99
Dec 3, 2015 08:12 PM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
JordanH
Oct 3, 2015 03:59 PM
Velocity1
Oct 2, 2015 08:01 AM
