PCM reflash / Edit
Old Feb 6, 2005 | 08:54 PM
GREGGO's Avatar
Default PCM reflash / Edit
If I reflash the PCM, will I lose the ability to use my LS1 Edit. Has anyone ever done it, or will I have to buy a new license? I asked about it in the PCM section, but thought I would ask here also. When I tuned the truck with Edit, I had the predator program on the truck. I never got a copy of the base line factory tune. If anyone has a file of a stock 2000 4.8 they can send me, that would be great too.
Old Feb 6, 2005 | 08:55 PM
BlownChevy's Avatar
blownerator
25 Year Member
You should be fine....as long as you dont change the Vin#.....and I dont think you can without the proper software.
Old Feb 6, 2005 | 09:00 PM
GREGGO's Avatar
damn your fast!!!!
Stalker!!
Old Feb 6, 2005 | 09:25 PM
ZDEN's Avatar
not positive, but if you reinstall the pred base tune you should be able to restore your factory tune from there with the pred. When i got my hpt's i copied the pred tune then used pred to set back to factory and then copied factory tune. once i had the factory tune saved i flashed the pcm with the pred tune i had copied and went from there. hope what i said makes sense.
Old Feb 6, 2005 | 09:28 PM
GREGGO's Avatar
The problem is the Predator was never able to put my stock tune back on. Don't know why, but it just wouldn't.
Old Feb 6, 2005 | 09:34 PM
ZDEN's Avatar
dumb ? did you try it from the digagnostic section where it says return to factory?
Old Feb 6, 2005 | 09:35 PM
BigTex's Avatar
You can have the dealer or a shop put the current GM tune back on with a TECH2 or similar device. They will need your VIN and a list of what options your truck came with. Then they can upload a stock base tune for your truck that has current big fixes as well.
Old Feb 6, 2005 | 09:45 PM
GREGGO's Avatar
So I can still use my LS1edit without having any problems?
ZDEN: It's been so long, I forgot the screens and what the options were. But I do remember messing with it on several occasions.
Old Feb 6, 2005 | 10:49 PM
BlownChevy's Avatar
blownerator
25 Year Member
Should be fine....I belive it learns the VIN#.
Old Feb 7, 2005 | 08:24 AM
GREGGO's Avatar
There is a code in the PCM that it locks to also and that's what I am worried about.
