pcm pin numer for fan control?
Old 12-18-2003, 08:50 PM
single digit dreamer
parish8's Avatar
i have the flexalite vsc too but it cycles WAY to fast, like every 30sec and i hate it. i am going to use it still but just control it with the pcm, just use it as a relay e basicly. also i will just set it real high so if something goes wrong with the pcm input it will still come on eventualy. should be done in an hour or so and be able to confirm that it works.
Old 12-18-2003, 09:29 PM
Flyer's Avatar
Parish .. something to keep in mind with that VSc, it's active for 30seconds after power is removed and it takes 6 seconds to initiate once it sees a signal from the ignition switch wire.
Old 12-18-2003, 09:34 PM
Performance Trucks Sponsor
FarmTruc's Avatar
Originally Posted by Tiburon
ya, it works, you have to use edit to enable the fans, set them to aux and set your fan temp.
good luck,
allen
Old 12-18-2003, 09:38 PM
HAZE's Avatar
Default "old truck"
parish, what year is your "old truck" with the whipple on it ? i need an edit file from a 6.0 w/ s.c to compare to mine. any chance ?
Old 12-18-2003, 09:49 PM
HAZE's Avatar
fans and whipple computer, when i asked whipples tech about my "floating temp guage" i was told that the whipple computer modifies the signal to the pcm, so it can run with the 160 thermo they provide. wouldn't that be a problem using the pcm to control the fans. the gauge is just a reflection of what the computer "thinks" the sending unit is reading. not an analog gauge.
Old 12-20-2003, 03:25 PM
blownerator
BlownChevy's Avatar
if anyone needs the pin that you have to add to #42 e-mail me I have them.
Old 12-21-2003, 11:12 AM
9 Second Club/LS1TECH Sponsor
Speartech's Avatar
Tiburon: Your fan schematic will work properly as drawn, but it would be more "automotive correct" to frame ground the fan motors and let the relays supply the +12 volts when they energize, instead of the opposite.
Just a tip for those wiring these up.
Old 12-21-2003, 11:27 AM
parish8's Avatar
jinxed myself with that one i guess, i did get the pcm to write once and i programed it to turn on AUX fans on and that didn't work, i am waiting to be able to rewrite it again but with the 2fan setting and see if that works.
maybe in a few weeks i will figure out how to get edit to work right and be able to report back.
Old 12-21-2003, 11:35 AM
blownerator
BlownChevy's Avatar
Keep us posted! I hope I dont have the same problems on my old bucket! I have the pin #42 wired and the programing done, I just need to hook it all up!
Porscharu914
14
01-20-2016 10:45 AM
99bluefirebird
09-17-2015 08:05 PM
97gmc
22
09-08-2015 10:56 PM
muncie21
09-07-2015 09:55 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
Quick Reply: pcm pin numer for fan control?
