pcm pin numer for fan control?
anyone know it?
#42 on the blue one. After just finishing the 5.3 conversion on my 94 work truck I can recite almost all the pins from memory!
Does the truck PCM turn the fans on if the AC is on?
http://www.ls1truck.com/howto/pcmfan...ng_frames.html |
Mine doesn't. I had to run a separate relay for A/C operation with the clutch wire used to trigger it.
i have been told it wont with the truck pcm either, it would be cool if someone would figure that part out.
thanks for the pin number. |
I'm currently running the flex-a-lite 282's with the VSC controller. The VSC has a relay for the A/C and a wire that taps into the A/C clutch wire. The thing I don't like is that the temperature control on the VSC seems to be stuck on low ~180. I have considered removing the sensor and using the #42 pin to turn the fans on instead.
vsc
my vsc screwed me once, apparently the rheostat had a bad connection and shut my fans down completely while i was towing a trailer up a hill. sprayed some contact cleaner in it and turned it back and forth a few times. haven't had any problems since. thinking of converting mine also.
What pin is it that you need in order to do this??
From what I have heard the truck pcm has the option to switch on the fans. It just has to be enabled using LS1Edit. Hope that is the right info.
